80 Plus Gold certified modular PSU with a huge seven year manufacturer warranty!
Unprecedented Power Protection
The Corsair Professional Series Gold power supply pushes the state of the art for reliable delivery of clean power under imperfect conditions. If you require mission-critical stability or you simply want one of the best power supplies available, the Professional Series Gold is for you.
A Fully Modular Cabling System
All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling -- the cables stay in place and connect to your new fully-modular Corsair power supply.
Incredible Efficiency
With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 Plus® Gold seal of approval, your guarantee that you're making the right choice for smart,efficient power delivery.
Ultra Low Noise - Hybrid Silent Fan Control
The Corsair AX850's energy-efficient design allows it to operate reliably with minimal cooling, and hence very low noise levels. The AX850's Hybrid Silent Fan Control technology offers three modes of cooling, depending on the load level. This includes a fanless mode of operation (0 rpm) up to about 20% load, a quiet, low fan speed cooling mode for typical loads up to around 50% load, and a higher performance cooling mode for more demanding loads. Noise levels still remain low even when fan speeds start to climb, thanks to the use of a premium-quality 120mm San Ace fan from industry-leader, Sanyo Denki.
A fully modular cabling system
All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow. And, when it's time to replace or upgrade your power supply, it can be removed from your system without interfering with your cabling - the cables stay in place and connect to your fully-modular Corsair power supply. -
Incredible efficiency
With 90% efficiency at 50% load, the Corsair Professional Series Gold power supply runs quieter, generates minimal excess heat, and saves you money every month. It's earned the 80 Plus Gold seal of approval, your guarantee that you're making the right choice for smart, efficient power delivery.
- CORSAIR Professional Series Gold AX850 - power supply - 850 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 3.29 g
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 70 A , -12V - 0.5 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 12 x 15 pin Serial ATA power , 8 x 4 PIN internal power , 2 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 120 mm fan
- 15 cm x 16 cm x 8.6 cm
- 7 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Frequency Required
- 50/60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output Current
- 80 PLUS Gold
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, fully modular
- FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC
- Limited warranty - 7 years
- 50 °C
- 15 cm
- 16 cm
- 8.6 cm
- 3.29 g
- Shipping Width
- 22.5 cm
- Shipping Depth
- 39.1 cm
- Shipping Height
- 15.1 cm
- Shipping Weight
- 4 kg
