Your basket is empty
Corsair 64GB V2 Survivor
Quicklinx: BF0MWS00 Mfr#: CMFSV3B-64GB
Your files are important - that's why you're taking them with you. Flash Survivor USB 3.0 helps keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
Corsair Flash Survivor - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000/ME/XP/Vista/7
5 years warranty
USB flash drive
Storage Capacity
64 GB
Compatibility
Non-specific
Interface Type
USB 3.0
Shockproof, waterproof, vibration-proof, aircraft-grade aluminium housing
Plug and Play
Limited warranty - 5 years
37 g
