Your basket is empty
Corsair 512GB Flash Voyager Slider X2 USB 3.0 Flash Drive
Quicklinx: C5HWWS00 Mfr#: CMFSL3X2-512GB
Capacity: 512GB
Interface: USB 3.0
£238.53 ex VAT
£286.23 inc VAT
Flash Voyager Slider X2 is a compact USB 3.0 drive that doesn’t sacrifice size for performance. It has a smart design, with a USB connector that retracts for protection when you’re not using it. A blue activity LED tells you at a glance if it’s transferring data. It supports USB transfer speeds up to 200MB/s read and 90MB/s write.
The Slider X2 is universally compatible with Windows, Mac OS X and even Linux, with no driver necessary. It’s also backward compatible with USB 2.0, so you can use it with virtually any desktop or notebook.
Corsair Flash Voyager Slider X2 - USB flash drive - 512 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
512 GB
Linux, Apple MacOS X, Microsoft Windows
5 years warranty
USB flash drive
Storage Capacity
512 GB
Compatibility
Non-specific
Read Rate
Up to 350 MB/s
Write Rate
Up to 270 MB/s
Interface Type
USB 3.0
Retractable connector, LED access indicator
5 years warranty
Service & Support Details
Limited warranty - 5 years
54 mm
23.3 mm
11 mm
9 g
Capacity: 512GB
Interface: USB 3.0
Brand: Corsair
Price Range Ex VAT: 150 - 300
