ValueSelect memory is tested to Corsair's tough standards and is stable, reliable, and compatible with virtually all major notebook and netbook PCs.
- CORSAIR Value Select - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3L SDRAM - SO-DIMM 204-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9 (9-9-9-24)
- Low Voltage, unbuffered
- Voltage
- 1.35 / 1.5 V
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL9 (9-9-9-24)
- Non-ECC
- Voltage
- 1.35 / 1.5 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
