Product
Corsair 4GB SO-DIMM DDR3L 1333
Quicklinx: 9H78WS00 Mfr#: CMSO4GX3M1C1333C9
ValueSelect memory is tested to Corsair's tough standards and is stable, reliable, and compatible with virtually all major notebook and netbook PCs.
CORSAIR Value Select - DDR3L - 4 GB - SO-DIMM 204-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Low Voltage, unbuffered
Voltage
1.35 / 1.5 V
4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Voltage
1.35 / 1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
