Your basket is empty
Corsair 4GB (2x2GB) DDR3 1333Mhz CL9 Value Select SODIMM  204 Pin Notebook Memory Kit
Quicklinx: 7JJPWS00 Mfr#: CMSO4GX3M2A1333C9
CMSO4GX3M2A1333C9 is Corsair's mainstream SODIMM memory solution for DDR3 laptops. Designed for current generation notebooks, mini-PCs and netbooks, Corsair's high density SODIMMs allow users to maximize memory bandwidth and minimize performance bottleneck to deliver superior user experience.
CORSAIR - DDR3 - 4 GB: 2 x 2 GB - SO-DIMM 204-pin
RAM memory
4 GB: 2 x 2 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
Voltage
1.5 V
4 GB: 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
2 x memory - SO-DIMM 204-pin
