Your basket is empty
Corsair 4GB (2x2GB) DDR3 1333Mhz CL9 Value Select  Desktop Memory Kit
Quicklinx: 7CLLWS00 Mfr#: CMV4GX3M2A1333C9
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR3 - 4 GB: 2 x 2 GB - DIMM 240-pin
RAM memory
4 GB: 2 x 2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
4 GB: 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Compatible Slots
2 x memory - DIMM 240-pin
