Corsair's mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair's new XMS heat spreaders, each module is built using carefully selected RAMs.
- One 4GB modules for use in high performance for the Intel Core i7, i5 and i3 Dual Channel systems
- Outrageously fast 1600MHz performance using 4GB of memory
- Low 11-11-11-30 latency
- 10 Years Manufacturers Warranty
- Density: 4GB (1x4GB Module)
- Speed: 1600MHz
- Timing: 11-11-11-30
- Type: DDR3
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.50V
- Warranty: 10 Years Manufacturers Warranty
- CORSAIR XMS3 - DDR3 - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11 (11-11-11-30)
- Black XMS heat spreader, Intel Extreme Memory Profiles (XMP), unbuffered
- Voltage
- 1.65 V
- Limited lifetime warranty
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- Non-ECC
- Voltage
- 1.65 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
