Corsair 4GB (1x4GB) DDR3 1333Mhz CL9 Value Select SODIMM  204 Pin Notebook Memory Module
Quicklinx: 7CLNWS00 Mfr#: CMSO4GX3M1A1333C9
CMSO4GX3M1A1333C9 is Corsair's mainstream SODIMM memory solution for DDR3 laptops. Designed for notebooks, mini-PCs and netbooks, Corsair's high density SODIMMs allow users to maximize memory bandwidth and minimize performance bottleneck to deliver superior user experience.
CORSAIR - DDR3 - module - 4 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
Voltage
1.5 V
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - SO-DIMM 204-pin
