Corsair 4GB (1 x 4GB) Value DDR3 1600MHz 240-pin DIMM CL11
Quicklinx: 8LT5WS00 Mfr#: CMV4GX3M1A1600C11
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
12 left in stock
£16.60 ex VAT
£19.92 inc VAT
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR3 - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11 (11-11-11-30)
Unbuffered
Voltage
1.5 V
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11 (11-11-11-30)
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-12800
Brand: Corsair
Stock Status: While stocks last
Stock Status: Clearance
