Corsair 4GB (1 x 4GB) Memory Module 1600MHz PC3-12800 DDR3 SO-DIMM
Quicklinx: 9H7PWS00 Mfr#: CMSO4GX3M1C1600C11
ValueSelect memory is tested to Corsair's tough standards and is stable, reliable, and compatible with virtually all major notebook and netbook PCs.
CORSAIR Value Select - DDR3L - module - 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11 (11-11-11-28)
Low Voltage, unbuffered
Voltage
1.35 V
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11 (11-11-11-28)
Non-ECC
Voltage
1.35 V
