Corsair 460X Crystal Series Tempered Glass ATX Mid-Tower Case
Quicklinx: CFS0WS00 Mfr#: CC-9011099-WW
Beautifully simple and engineered to perform: the Crystal 460X has two-panel tempered glass, Direct Airflow cooling technology, is compact, expandable, and with advanced fan, you can customize to your heart's content.
  • Freedom to customize
    Crystal 460X was engineered to pack all the performance and expandability you need into a beautifully modern and compact case design. Put your build on display through beautiful two-panel tempered glass and keep it all running cool and quiet with Direct Airflow technology.
  • Liquid cooling capable
    With room for front, top, and rear radiators, you can choose to quiet down your GPU and CPU with liquid coolers just about wherever you want to.
  • Direct Airflow Path
    Drive cages are moved up and out of the path of cool air from the front intake fans and high-temperature components.
  • Minimal setup
    With tool-free drive installation and three-point dust filter access, the Corsair Crystal 460X is easy to build - and even easier to keep clean. You'll spend less time on setup and maintenance, and more time enjoying your PC.
CORSAIR Crystal Series 460X - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front dust filter, Direct Airflow Path design, tool-free drive holder, Liquid Cooling Ready
No power supply (ATX)
22 cm x 44 cm x 46.4 cm
7.97 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
5
Product Material
Steel
Cooling System
Front: 120 mm fan x 1 / intake / 2 x 140 mm fan or 3 x 120 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
370 mm
Power Supply Max Length
200 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
22 cm
44 cm
46.4 cm
7.97 kg
