Corsair 460X Crystal Series RGB Tempered Glass Compact ATX Case
Quicklinx: CFS1WS00 Mfr#: CC-9011101-WW
Beautifully simple and engineered to perform: the Crystal 460X has two-panel tempered glass, Direct Airflow cooling technology, is compact, expandable, and with RGB fans, is not afraid of the spotlight.
  • RGB LED fans
    Light up your build with brilliant LED effects and draw ample cool air directly to your components without the turbulence that can cause fan hum.
  • Room for activities
    Crystal 460X was engineered to pack all the performance and expandability you need into a beautifully modern and compact case design. Put your build on display through beautiful two-panel tempered glass and keep it all running cool and quiet with Direct Airflow technology.
  • Style is everything
    Make your build stand out from the crowd by coordinating the custom-molded translucent blades with your build for a sleek, brilliant look - all visible through the tempered glass panels.
  • Clean, modern lines with an all steel exterior
    Get rid of those plastic cases - the 460X has full steel front and top panels for extra durability and gorgeous good looks.
  • Direct Airflow Path
    Drive cages are moved up and out of the path of cool air from the front intake fans and high-temperature components.
  • Minimal setup
    With tool-free drive installation and three-point dust filter access, the Corsair Crystal 460X is easy to build - and even easier to keep clean. You'll spend less time on setup and maintenance, and more time enjoying your PC.
CORSAIR Crystal Series 460X RGB - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front dust filter, Direct Airflow Path design, tool-free drive holder, Liquid Cooling Ready, supports 120/240/280/360 mm radiator in front panel
No power supply (ATX)
22 cm x 44 cm x 46.4 cm
7.97 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
5
Product Material
Steel, tempered glass
Cooling System
Front: 120 mm fan x 3 / intake / 2 x 140 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
370 mm
Power Supply Max Length
220 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
22 cm
44 cm
46.4 cm
7.97 kg
