Your files are important - that's why you're taking them with you. Flash Survivor Stealth USB 3.0 flash drives help keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
- Corsair Flash Survivor Stealth - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- OS Required
- Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000/ME/XP/Vista/7
- 5 years warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Compatibility
- Non-specific
- Interface Type
- USB 3.0
- Shockproof, waterproof, vibration-proof, aircraft-grade aluminium housing
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 36.3 g
