Your basket is empty
Corsair 2GB DDR3 1333MHz CL9 DIMM Memory
Whilst Stocks Last!
Clearance
Quicklinx: 679NWS00 Mfr#: VS2GB1333D3
Corsair Memory is specifically designed for rock-solid stability in demanding applications. Data lines are carefully engineered for noise immunity; clock lines are optimized for minimum skew. All modules use JEDEC-compliant six-layer.
Corsair - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
Voltage
1.5 V
2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
