Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
- CORSAIR Value Select - DDR - kit - 2 GB: 2 x 1 GB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
- Product Type
- Memory kit
- Capacity
- 2 GB: 2 x 1 GB
- Memory Type
- DDR SDRAM - DIMM 184-PIN
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- Unbuffered
- Limited lifetime warranty
- Capacity
- 2 GB: 2 x 1 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR SDRAM
- Form Factor
- DIMM 184-PIN
- Speed
- 400 MHz (PC3200)
- Latency Timings
- CL3
- Non-ECC
- Unbuffered
- Module Configuration
- 128 x 64
- Compatible Slots
- 2 x memory - DIMM 184-PIN
Customer reviews
Write a review for the Corsair 2GB (2x1GB) DDR1 400Mhz CL3 Value Select 184 Pin Desktop Memory Kit here!
Faultless
Reviewed by Qbert. Review Posted 20/02/2007
Installed no problems. Works well along side exsisting ram. now have 2.5GB. Dabs service great as usual. On the door the following day. Also £10 with email coupon.
Overall
Ease of use
Value for money
Bad Stick
Reviewed by Neil. Review Posted 02/03/2007
Well after a week, one of the sticks started to playup. But these things happen and the dabs return process is as painless and easy is ever. New sticks work like a dream.
Overall
Ease of use
Value for money
Simple
Reviewed by Anonymous Review Posted 07/08/2008
Awesome. 2 days, arrived, in, working. fantastic value.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
