Product
Brand
Corsair 2GB (1x2GB) DDR2 800Mhz CL5 Value Select SODIMM  200 Pin Notebook Memory Module
Quicklinx: 6YZZWS00 Mfr#: VS2GSDS800D2
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR2 - 2 GB - SO-DIMM 200-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Unbuffered
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
