Corsair Memory is specifically designed for rock-solid stability in demanding applications. Data lines are carefully engineered for noise immunity; clock lines are optimized for minimum skew. All modules use JEDEC-compliant six-layer.
- CORSAIR - DDR3 - module - 2 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - unbuffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9 (9-9-9-24)
- Unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL9 (9-9-9-24)
- Non-ECC
- Unbuffered
- Voltage
- 1.5 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
