Corsair 16GB V2 Survivor Stealth
Quicklinx: BF0DWS00 Mfr#: CMFSS3B-16GB
Capacity: 16GB
Interface: USB 3.0
£15.23 ex VAT
£18.27 inc VAT
Your files are important - that's why you're taking them with you. Flash Survivor Stealth USB 3.0 flash drives help keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
  • USB 3.0 speed
    If you move a lot of data, you've noticed that as convenient as USB flash drives are, they never seem to be as fast as you'd like. USB 3.0 changes the game. Flash Survivor Stealth USB 3.0 offers read speeds up to four times faster than traditional USB 2.0 drives. It's fast enough to view most videos directly from your Flash Survivor Stealth, without having to take the usual extra step of copying it to a hard drive first.
  • High-performance USB 2.0 compatibility
    Not only is Flash Survivor Stealth USB 3.0 backward compatible with USB 2.0 - it offers great performance, too. No matter how up-to-date your PC is, you'll be able to quickly take care of moving your files and be off on your next adventure.
  • Universal compatibility
    It works with Microsoft Windows, Mac OS X, and even Linux without drivers, and there's no software to install. Just plug it in, and go. If your computer has a USB 2.0 or 3.0 connector, you can use Flash Survivor Stealth USB 3.0.
CORSAIR Flash Survivor Stealth - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000/ME/XP/Vista/7
5-year warranty
USB flash drive
Storage Capacity
16 GB
Compatibility
Non-specific
Interface Type
USB 3.0
Shockproof, waterproof, vibration-proof, aircraft-grade aluminium housing
Plug and Play
Limited warranty - 5 years
36.3 g
Capacity: 16GB
Interface: USB 3.0
Brand: Corsair
Price Range Ex VAT: 0 - 50
