Your files are important - that's why you're taking them with you. Flash Survivor USB 3.0 helps keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
USB 3.0 speed
If you move a lot of data, you've noticed that as convenient as flash drives are, they never seem to be as fast as you'd like. USB 3.0 changes the game. Flash Survivor USB 3.0 offers read speeds up to four times faster than traditional USB 2.0 drives. It's fast enough to view most videos directly from your Flash Survivor, without having to take the usual extra step of copying it to a hard drive first. -
High-performance USB 2.0 support
Not only is Flash Survivor USB 3.0 backward compatible with USB 2.0 - it offers great performance, too. No matter how up-to-date your PC is, you'll be able to quickly take care of moving your files and be off on your next adventure.
- CORSAIR Flash Survivor - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 16 GB
- OS Required
- Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000/ME/XP/Vista/7
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Interface Type
- USB 3.0
- Shockproof, waterproof, vibration-proof, aircraft-grade aluminium housing
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 37 g
