Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance Pro Series - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1866 MHz / PC3-15000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1866 MHz (PC3-15000)
- Latency Timings
- CL10 (10-11-10-30)
- Dual channel, 8 Layers PCB heatspreader, Intel Extreme Memory Profiles (XMP 1.3), anodized aluminum heatspreader, Vengeance Pro Series heatspreader, unbuffered
- Voltage
- 1.5 V
- Limited lifetime warranty
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- Non-ECC
- Voltage
- 1.5 V
- Colour Category
- Black, red
