Product
Brand
Corsair 16GB (2x8GB) Vengeance Performance SODIMM 2400MHz CL16 DDR4
Quicklinx: BVWYWS00 Mfr#: CMSX16GX4M2A2400C16
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance - DDR4 - 16 GB: 2 x 8 GB - SO-DIMM 260-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL16 (16-16-16-39)
Unbuffered
Voltage
1.2 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL16 (16-16-16-39)
Non-ECC
Unbuffered
Voltage
1.2 V
Colour Category
