Your basket is empty
Corsair 16GB (2x8GB) Vengeance DDR4 2666MHz 288pin DIMM Red LED
Quicklinx: C9LCWS00 Mfr#: CMU16GX4M2A2666C16R
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance LED - DDR4 - 16 GB : 2 x 8 GB - DIMM 288-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz ( PC4-21300 )
Latency Timings
CL16 ( 16-18-18-35 )
Dual channel, Vengeance heatspreader, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), red activity LED's, 10 Layers PCB heatspreader , unbuffered
Voltage
1.2 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
Non-ECC
Voltage
1.2 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 2666 MHz - 1.2 V - CL16 - 16-18-18-35
Colour Category
