Corsair 16GB (2x8GB) DDR3 1600Mhz CL10 Vengeance Black Performance Desktop Memory Kit
Quicklinx: 830YWS00 Mfr#: CMZ16GX3M2A1600C10
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL10 (10-10-10-27)
Intel Extreme Memory Profiles (XMP), dual channel, Vengeance heatspreader, unbuffered
Voltage
1.5 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL10 (10-10-10-27)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
