Corsair 16GB (2 x 8GB) Vengeance LP DDR3 1600MHz DIMM 240-pin CL9
Quicklinx: 9R0PWS00 Mfr#: CML16GX3M2A1600C9
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Perfect for when you need high performance and low clearance.
Vengeance Low Profile heat spreaders have a reduced height of 1.03" (26.25mm). They’re designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
Great for overclocking
Each Vengeance memory module is built from DRAM ICs specially selected for performance potential, to allow you to explore the limits of system overclocking.
If you're new to overclocking, full support for Intel Extreme Memory Profile (Intel XMP) makes it easy. Add Vengeance to your XMP-compatible system and it can automatically select the maximum possible overclocking performance, quickly and easily.
The Vengeance family: outstanding performance at an attractive price
Make your system build budget go farther
If you're a gamer, a system builder, or just an all-around performance enthusiast, you should demand performance and reliability, regardless of your budget. If you need dependable, overclockable memory at an attractive price, Vengeance is a great choice.
Rigorous screening and exhaustive testing
Speed is nothing without stability. That’s why Vengeance DDR3 memory kits, like all Corsair memory products, are carefully screened and tested to exacting standards. They’re backed up with a limited lifetime warranty that lets you buy with confidence.
  • Great looking, great overclocking memory
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
CORSAIR Vengeance - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-24)
Dual channel, Intel Extreme Memory Profiles (XMP 1.3), Vengeance low profile heatspreader, unbuffered
Voltage
1.5 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
