Corsair 128GB Flash Voyager Mini USB3.0 Flash Drive
Quicklinx: C0S4WS00 Mfr#: CMFMINI3-128GB
Flash Voyager Mini is the tiny USB flash drive with full-size USB 3.0 performance. The USB 3.0 connector allows for optimal file transfer speed with advanced systems, and it's fully compatible with USB 2.0. It has a detachable loop for attaching to your key ring, and the durable brushed metal housing resists wear and tear.
  • USB 3.0 performance
    It's small, but it gives you full-size speed. Enjoy optimized performance when it's connected to a USB 3.0 port.
  • Compact size
    It goes almost anywhere and you won't think about it when you're not using it.
  • Brushed metal housing
    The sleek design protects your data and resists wear and tear. The logo is laser-etched, so it won't rub off.
  • Key ring convenience
    The Mini has a rubber strap and metal loop for attaching to your key ring. You might never say "I left my USB flash drive at home" again.
CORSAIR Flash Voyager Mini - USB flash drive - 128 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
128 GB
Linux, Apple MacOS X, Microsoft Windows
5-year warranty
USB flash drive
Storage Capacity
128 GB
Interface Type
USB 3.0
Metal body, key ring loop
Limited warranty - 5 years
3.2 cm
15 g
