CORSAIR HX series power supplies give you extremely tight voltage regulation, quiet operation, Platinum-certified efficiency, and a fully modular cable set. Built with all Japanese 105°C capacitors, they're a great choice for high performance PCs where reliability is essential.
Quiet, efficient operation
80 PLUS Platinum efficiency reduces operating cost and excess heat, and Zero RPM fan mode ensures virtual silence at low and medium loads. -
100% Japanese 105 °C capacitors
Premium internal components ensure solid power delivery and long term reliability. -
Zero RPM fan mode
Since the fan doesn't turn on until it's needed, you'll enjoy virtually silent operation at low and medium loads. -
Power in your hands
Toggle single +12 V rail or multi +12 V rail mode. In the "SINGLE" position, the full output capability of the power supply's +12 V rail is available to any and all connectors, while in the "MULTIPLE" position, each individual connector has Over-Current Protection so no more than 40 A of current can be delivered on any given cable. -
Easy installation
The fully modular DC cables make builds and upgrades easy, with clean, great-looking results.
- CORSAIR HX Series HX1000 - power supply - 1000 Watt
- Power supply - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Platinum
- 1.95 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 83.3 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 8 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- Included Accessories
- Case badge, cable ties, mounting kit
- 15 cm x 18 cm x 8.6 cm
- 10 years warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- 80 PLUS Platinum
- Cables Included
- Power cable kit
- Cooling System
- 135 mm fan
- Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, temperature controlled fan, Zero RPM fan mode, fluid dynamic bearing cooling fan, switchable single/multi 12V rails, temperature sensor, fully modular
- CSA, UL, TUV, C-Tick, cUL, CB, FCC, RoHS, WEEE, ICES, REACH, KC, China RoHS, RCM, CU
- Limited warranty - 10 years
- 15 cm
- 18 cm
- 8.6 cm
- 1.95 kg
- Shipping Width
- 22.5 cm
- Shipping Depth
- 39.2 cm
- Shipping Height
- 15.2 cm
- Shipping Weight
- 3.95 kg
