Making awesome movies should be simple, fun, and lightning fast. So forget the tech talk and complicated features, and say hello to the streamlined Pinnacle Studio - no engineering degree required. Import clips and polish them right inside the built-in media organizer. Storyboard first drafts and even create movies automatically - or refine edits with frame accuracy on a 6-track timeline and spice things up with over 1500 2D/3D effects. Built-in media cloud access from box makes your files available anywhere, anytime - including projects you start on Pinnacle Studio for iPad. One click shares your HD or stereoscopic 3D videos on Facebook, YouTube, and Vimeo. With the included video tutorials, you'll be creating movies like a pro immediately.
Start making movies today - it's fast and easy
With Pinnacle Studio as your creative partner, you'll spend less time making videos and more time sharing them. It has included an extensive collection of video tutorials from the training experts at class on demand, designed to get you creating movies like a pro in no time. Whether you're just getting started or wanting to enhance your skills, it's as simple as going online or popping in the included "getting started with studio" DVD. -
Import your digital media
Import your videos and photos manually or automatically from virtually any device - amcorders, digital cameras, webcams, tablets, mobile phones, handheld audio recorders, and more. You can even import 3D clips from cameras like GoPro. Pinnacle Studio also supports tape-based and analog devices, and even imports audio files in 5.1 surround format. -
Edit anywhere, anytime with iPad and the cloud
Pinnacle Studio features integrated cloud access so that your media files and projects are always handy, no matter where you are or what you're doing. Project packages lets you bundle together all of the media files related to a given movie, taking the work out of organizing and assuring that you always have all the files you need. You can even start editing projects on the go with Pinnacle Studio for iPad, and then transfer them to Pinnacle Studio for polishing. -
Organize and polish your media
With the built-in media library, it's simple to organize and rate your favorite video clips, photos, music, and other creative elements so you can easily find and reuse them in various projects. You can even correct and enhance your source media right inside Pinnacle Studio's media library without the need for additional apps. Crop, pan-and zoom, and eliminate red eye from photos. EQ and clean up noisy audio. Color-correct video and stabilize shaky footage with Hollywood-proven technology. The changes and effects you add to your files in the media library apply whenever you use them in a project or export them for other uses - saving time and streamlining your movie making. -
Edit your movies - fast
Pinnacle Studio gives you the flexibility to make movies the way that best suits you or the needs of a given project. For instant results, drag-and-drop your desired media elements from the library into SmartMovie or SmartSlide to automatically produce great videos - complete with music. You can also use Storyboard mode to easily create first drafts and visualize how your story will unfold. At any point, you can switch to the timeline for more traditional editing. Pinnacle Studio lets you set source clip trim in/out points, then send trimmed clips right to the timeline to include in your project. Six tracks give you the ability to create sophisticated picture-in-picture and multi-layer effects in HD or 3D with frame accuracy - just like a Hollywood pro. It all happens at state-of-the-art lightning speeds thanks to optimization for the latest acceleration technologies like 64-bit operation, NVIDIA CUDA, and Intel Quick Sync Video. -
Make your own stereoscopic 3D movies
From importing to editing to sharing, Pinnacle Studio puts the power of industry-leading, Hollywood-proven stereoscopic 3D technology right in your hands. Import 3D video clips from sources like GoPro 3D cameras. Edit in various viewing modes, add true 3D effects, and enjoy the best quality with NVIDIA 3D Vision optimization and exclusive GeForce support. Export to YouTube 3D, AVCHD 3D, and more for viewing on 3D HDTVs, Sony PS3, and other 3D devices. -
Pinnacle Studio even lets you mix 2D and 3D in the same project
Pinnacle Studio also has advanced stereoscopic 3D features you won't find anywhere else, like editing 3D in the timeline just like HD. The partnership with NVIDIA allows exclusive NVIDIA 3D Vision display in both full-screen and window modes. View 3D on dual monitors and export "side-by-side" formats recognized by most 3D HDTVs. Auto-color correct for both eyes and control stereoscopic 3D depth (parallax effect). When you're ready to go 3D, Pinnacle Studio has everything you need. -
Enhance and energize with over 1500 effects
Add excitement and polish to your movies with over 1500 2D/3D effects, animated titles and transitions. The included montage templates provide preset themes - weddings, sports, holidays, sci-fi, comics and more - for instant professional results with just a few clicks. You can customize montage templates for exactly the look you're after. Use stop-motion capture to create amazing animations and fast-motion effects like you see on the big screen. Pinnacle Studio even lets you superimpose people you've shot in front of a green screen over different backgrounds. -
Music to your ears
No movie is complete without a soundtrack. Pinnacle Studio lets you add music with the included Scorefitter library of royalty-free sounds and songs - and they even automatically adjust to fit the length of your movies. Of course, you can also import tracks from other sound libraries or add your own original compositions. -
Share your masterpieces
When you're ready to share your videos with family and friends, a single click in Pinnacle Studio posts your HD and 3D videos on Facebook, YouTube, and Vimeo. You can also easily create DVDs and AVCHD discs, and export to popular formats like Adobe Flash FLV, MPEG-4, and DivX, as well as popular devices like Microsoft Xbox, Sony PS3, Nintendo Wii, Apple TV and Apple iPad. With Pinnacle Studio, the world is your screen.
- Pinnacle Studio (v. 19) - box pack - 1 user
- Product Type
- Box pack
- Category
- Creativity application - video editing & production
- Version
- 19
- Licence Qty
- 1 user
- Platform
- Windows
- Language
- Danish, Czech, English, French, Italian, Polish, Finnish, Swedish, Russian, Spanish, Dutch
- Localisation
- Europe
- Category
- Product Type
- Box pack
- Version
- 19
- Platform
- Windows
- Language
- Localisation
- Europe
Licencing
- Licence Qty
- 1 user
- Supported OS
- Microsoft Windows 7, Windows 10, Windows 8.x
- Hardware Requirements
- Microsoft Windows (32 bit) - Core Duo - 1.8 GHz - RAM 2 GB - HD 8 GB , Microsoft Windows (64 bit) - Core Duo - 1.8 GHz - RAM 4 GB - HD 8 GB
- Additional Requirements
- Internet connection, 1024 x 768 monitor resolution
