Product
Corel CorelDRAW Technical Suite X7
Quicklinx: C75TWS00 Mfr#: CDTSX7MLDVD
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£638.85 ex VAT
£766.62 inc VAT
CorelDRAW Technical Suite X7 features Corel DESIGNER for dedicated technical design and illustration, including advanced isometric drawing tools, leading file compatibility, and publishing capabilities for print, online and mobile. The program helps technical communication professionals create projects quickly by accessing and repurposing technical design assets from various sources. The advanced Lattice3D Studio CAD add-on supports 3D CAD assembly formats from CATIA, Inventor, NX, PTC Creo, SolidWorks and others. With file export capabilities covering graphics, bitmap and other document formats, from Microsoft Office, CGM, SVG, EPS, TIFF, JPEG and PNG to PDF/A and S1000D industry standards, CorelDRAW Technical Suite X7 allows users to distribute technical communications to a variety of media publishing options.
  • Projected drawing modes
    Create isometric or other parallel projected illustrations for assembly and maintenance instructions by dynamically drawing on a projected plane. Project your existing planar objects to a desired plane instead of manually calculating the skew angle and rotation.
  • Advanced dimension tools
    Eliminate the need to draw and project dimension objects in multiple steps thanks to the advanced dimension tools. Display precise measurement values in build plans and more, including radial and diameter dimensioning. Plus, with projected dimension options, your projected drawings can be quickly documented with precise and dynamic dimension lines and text.
  • 3D PDF publishing
    Publish to 3D PDF with interactive viewing of 3D content in combination with other visual and text elements. Export from Corel DESIGNER to 3D PDF to generate output with all pertinent data and graphics in one document for cross-media publishing. 3D PDF files can be viewed with free PDF reader applications that are installed on almost any desktop or laptop computer.
  • 3D import and visualization tools
    Add context to your technical projects by using 3D views and models in your illustrations. With the integrated Lattice3D Studio, you can create high-quality renderings from 3D views imported from DWG, 3DS, VRML and XVL files, or use the unique Insert 3D functionality to embed 3D models as editable 3D elements with a high-resolution preview.
  • Insert 3D models into technical illustrations
    Choose one of two ways to insert a 3D model into a Corel DESIGNER document; either insert it as an external reference or embed the 3D model (XVL file) in the Corel DESIGNER document. When embedding the 3D file, the 3D model can be accessed for modifications within the Corel DESIGNER (.DES) file. You can then share the .DES file with other users who can access the embedded 3D file.
  • Translation Memory System (TMS) support
    Reach a worldwide audience with an option that allows you to send text content from your graphics file in Corel DESIGNER to Translation Memory Systems (TMS) using XLIFF standard, and receive translated content from TMS. The translation results can then be imported into the existing document to create a new file for the specific language. With illustrations instantly available in multiple languages, companies can satisfy their global business needs.
  • Easy access to design assets
    Instantly find images on your local network and search online portals and websites, and easily access content using built-in content assistant Corel CONNECT . Organize assets by type or project in trays that are shared between Corel DESIGNER, CorelDRAW, Corel PHOTO-PAINT and Corel CONNECT for maximum efficiency. Utilize the Content Exchange and the tray synchronization option with Microsoft OneDrive.
  • Redesigned customizable user interface
    Leverage the option of multiple displays, using one screen for illustration and 3D work, and one for documentation or additional tools. Advanced workspaces offer Lite for beginners, Technical for pros doing isometric illustrations, Diagramming for pros using flowcharts and diagrams, and the Adobe workspace for Corel DESIGNER users coming from other applications.
  • Precise illustration tools
    Add greater levels of detail to your technical illustrations with projected shape tools, including Thread, Well, Cylinder and Prism tools. Quickly and easily draw thread and well shapes in projected space for the creation of bolts, nuts and more.
  • Precision layout and drawing tools
    Capture your intended drawing shape with exactness using the Outline Position options that recognize line width measurements for object dimensions. Use the Alignment Guides so all elements of your technical illustration are intuitively, yet precisely, placed in their intended positions.
  • Parallel line drawing tool
    Speed up the creation of all kinds of technical graphics, from wiring diagrams to architectural designs with the Parallel Drawing mode in Corel DESIGNER X7. You can simultaneously draw multiple parallel curves while controlling the distance between them. Use the Parallel Drawing toolbar to set the number of parallel curves to create and position them with precision.
  • Streamlined callout creation
    Track essential design details and key information with dynamic callout tools. Sticky callouts will connect or "stick" to source objects as they are moved around or modified. You can also link callout text to source shape metadata. Callouts based on object metadata are dynamic, helping you efficiently and consistently implement updates and changes.
  • Hotspot capabilities
    Use the callout drawing tool in Corel DESIGNER to add interactive functionality to callout shapes in technical publications. With the Object Data Manager docker, you can list metadata fields, such as WebCGM metadata, for callout shapes. Object data items can be edited so that callout shapes can be manually edited as hotspots for WebCGM output.
  • Total control over fills and transparency
    We've created our most powerful fill engine ever, giving you complete control over your fountain, bitmap pattern, vector pattern and hatch fills. Plus, the new Fill dialog includes access to Content Exchange and fill libraries in Corel DESIGNER.
  • Drawing scale control
    Create your illustrations and diagrams in accurate scale with the drawing scale control. View the active drawing scale, switch to another preset or set a custom scale at any time. In addition, Corel DESIGNER X7 maintains the drawing scale when importing a vector illustration from a 3D model view so that imported views can be placed at a precise scale.
  • Equation Editor
    Manage mathematical equations as editable elements within technical illustrations using the newly integrated Equation Editor. Mathematical and scientific formulas can be inserted and displayed in the drawing, and then modified when needed. Existing equations from older CorelDRAW documents can be opened or imported for use in Corel DESIGNER equations.
  • QR Code generator
    Create time-saving QR codes with Corel DESIGNER X7 and add scalable QR codes to a drawing, allowing you to give technicians in the field the ability to link to online technical documentation from printed documentation or machine labels using a smartphone.
  • Easy color harmony editing
    The enhanced Color Styles docker makes it easier than ever to view, arrange, and edit color styles and harmonies. You can now specify the brightness value, and preserve saturation and hue while adjusting a color. The harmony rules let you snap all colors in a color harmony to a rule-based system, so you can modify those colors while preserving the color harmony.
  • Easy font preview and advanced character tools
    Find the perfect font for any project. The Font Playground lets you preview and experiment with different fonts before bringing them into your design. Plus, the revamped Insert Character docker automatically shows you all the characters, symbols and glyphs associated with your font, making them easier than ever to find and insert.
  • Technical publication standards support
    Keep up with current industry requirements with the ability to publish to a variety of industry-standard file formats, including WebCGM (with S1000D profile support) for Interactive Electronic Technical Manuals (IETM), Illustrated Parts Catalogs (IPC) creation, and PDF support, including ISO standard PDF/A and 3D PDF.
CorelDRAW Technical Suite X7 - box pack - 1 user
Box pack
Category
Creativity application - graphics & image editing, CAD, 3D modelling
Licence Qty
1 user
Platform
Windows
Language
English, German, French
Distribution Media
DVD-ROM (DVD case)
Category
Box pack
Platform
Windows
Distribution Media
DVD-ROM (DVD case)
Language
Licencing
Licence Type
1 user
Supported OS
Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Hardware Requirements
Microsoft Windows - Intel Core Duo RAM 2 GB - HD 1 GB , Microsoft Windows - Athlon 64 RAM 2 GB - HD 1 GB
Additional Requirements
Mouse or compatible device, DVD-ROM, 1024 x 768 monitor resolution, Internet Explorer 8.0 or later
Type: Creativity - 3D modelling
Type: Creativity - CAD
Type: Creativity - graphics & image editing
Compatibility: PC
Media: DVD-ROM
Brand: Corel
Price Range Ex VAT: 500 - 750
