Product
Brand
CoolerMaster Vanguard V 1200W 80plus Platinum Power Supply
Quicklinx: B5HBWS00 Mfr#: RSC00-AFBAG1-UK
Cooler Master developed the V-series to re-ascertain its position as the worlds top power supply brand. It features outstanding efficiency, especially at typical low idle loads, excellent hold up times, voltage stability and ripple suppression. It only uses highest grade Japanese capacitors, most of them solid capacitors, as well as a massive high quality 42mm transformer.
And thanks to high quality FDB fans V-series PSUs are extremely cool and quiet. The V-series uses a fully modular cable system with beautiful all black, extra slim flat-ribbon cables. This makes cable management a breeze and results in nice looking clean builds with the best possible airflow.
Cooler Master V Series V1200 - power supply - 1200 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Platinum
Europe
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1200 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin +12V with detachable 4 pin section , 12 x 8 pin PCI Express power with detachable 2 pin section , 9 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
135 mm fan
15 cm x 19 cm x 8.6 cm
7 years warranty
ATX12V 2.31
PSU Form Factor
ATX
Europe
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1200 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 100 A , -12V - 0.5 A , +5VSB - 3 A
Efficiency
93%
Modular Cable Management
80 PLUS Platinum
MTBF
100,000 hours
Cooling System
135 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection
TUV, BSMI, CCC, FCC, KC, EAC, RCM
Limited warranty - 7 years
15 cm
19 cm
8.6 cm
