The great Cooler Master Silencio FP series introduces desired features to the 120 mm cooling fan offerings. Thanks to its Loop Dynamic Bearing (LDB), the life expectancy is pushed up to an incredibly long hours. Silencio FP’s exclusive driver IC assists in making the fan produce ultra-low vibrations and noise while saving more power with very low energy requirements. Its Smart Fan Engine prevents damage with fan jam detection and protection.
- Cooler Master Silencio FP 120 PWM - case fan
- Product Type
- Case fan
- Package Content
- 3-pin plug to 4-pin Molex adapter, 4 anti-vibration screws, 4 screws
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Loop dynamic bearing
- Rotation Speed
- 800-1400 rpm
- Air Flow
- 16.4-44 cfm
- Noise Level
- 6.5 - 14 dBA
- Power Connector
- 4 pin Molex connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support
- 12 cm x 12 cm x 2.5 cm
- 158 g
- 5-year warranty
- Product Type
- Case fan
- Package Content
- 12 cm
- 12 cm
- 2.5 cm
- 158 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 800-1400 rpm
- Air Flow
- 16.4-44 cfm
- Air Pressure
- 0.47-1.69 mm
- Noise Level
- 6.5 - 14 dBA
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.03 A
- Power Consumption
- 0.36 W
- Mounting Kit
- Included
- MTBF
- 160,000 hour(s)
- IP6X
- Limited warranty: - 5 years
