Product
CoolerMaster Silencio 652s Mini ITX Micro ATX USB 3.0 SD Card Reader
Quicklinx: B5H5WS00 Mfr#: SIL-652-KKN2
Case Form Factor: Mid tower
Motherboard Form Factor: ATX
Colour: Midnight black
38 in stock
£87.27 ex VAT
£104.72 inc VAT
The Silencio 652S delivers uncompromising, whisper-quiet performance. Silencio 652S features support for 120/240 mm water cooling systems with removable covers on the top and side panels. A large interior ensures ample space for the high-end graphics cards and CPU coolers, while adjustable HDD/SSD trays provide support for up to 9 HDDs or 10 SSDs. Maintenance is a breeze with multiple dust filters throughout the chassis (top, bottom, front, side).
Cooler Master Silencio 652S - mid tower - ATX
System cabinet
Mid tower
Midnight black
Built-in Devices
Card reader
I/O Connectors
2 x USB 3.0 , 2 x USB 2.0 , 1 x microphone , 1 x audio line-out
Supported Motherboards
ATX, microATX
Card Reader
Card reader
System Cabinet Features
Side panel dust filter, top panel dust filter, front dust filter, supports 240 mm radiator in front panel, supports 240 mm radiator in top, supports 120 mm radiator in rear, removable HDD cage, bottom dust filter
No power supply
Specification Compliance
ATX / PS/2
22 cm x 50.86 cm x 50.7 cm
10.4 kg
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX / PS/2
Internal Bays Qty
10
Front Accessible Bays Qty
3
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Built-in Devices
Card reader
Midnight black
Cooling System
Front: 120 x 120 x 25 mm fan x 2 / intake / 1200 rpm / 38 cfm / 11 dBA / Loop Dynamic Bearing , Rear: 120 x 120 x 25 mm fan x 1 / exhaust / 1200 rpm / 38 cfm / 11 dBA / Loop Dynamic Bearing , Top: 120/140/180/200 mm fan mount x 1 , Side: 180/200 mm fan mount x 1 , Bottom: 120/180 mm fan mount x 1 , Internal: 120 mm fan mount x 1
CPU Cooler Max Height
168 mm
Video Card Max Length
423 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 9 (total) / 9 (free) x internal - 2.5" / 3.5" shared , 1 (total) / 1 (free) x internal - 2.5"
Expansion Slots
8
2 x USB 3.0 , 2 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
No power supply
Max Supported Qty
1
22 cm
50.86 cm
50.7 cm
10.4 kg
Brand: CoolerMaster
Price Range Ex VAT: 50 - 100
