CoolerMaster Silencio 452 ATX USB 3.0 SD Card Reader ATX Case
Quicklinx: 9FR1WS00 Mfr#: SIL-452-KKN1
Case Form Factor: Tower
Motherboard Form Factor: ATX
Colour: Midnight black
£65.48 ex VAT
£78.57 inc VAT
The matte front door and side panels of the cabinet are equipped with noise absorbing materials for extreme silence. There are two pre-installed fans in the front and rear for optimized airflow, Moreover, the Cooler Master Silencio 452 provides liquid cooling ready for professionals and enthusiasts.
Cooler Master Silencio 452 - tower - ATX
System cabinet
Tower
Midnight black
Built-in Devices
Card reader
I/O Connectors
2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone , 1 x audio line-out
Supported Motherboards
ATX, microATX
System Cabinet Features
Front panel door, removable HDD rack, front dust filter, supports 240 mm radiator in front panel, supports 120 mm radiator in rear, side panel sound-damping foam mats, bottom dust filter
No power supply
19 cm x 49.7 cm x 44.9 cm
6.14 kg
Tower
Max Mainboard Size
ATX
ATX, microATX
Internal Bays Qty
8
Front Accessible Bays Qty
2
Supported Flash Memory Cards
SD Memory Card
Built-in Devices
Card reader
Midnight black
Cooling System
Front: 120 mm fan x 1 / 800 rpm / 2 x 120/140 mm fan supported , Rear: 120 mm fan x 1 / 800 rpm / 1 x 80/90 mm fan supported
CPU Cooler Max Height
158 mm
Video Card Max Length
386 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 3.5" , 2 (total) / 2 (free) x front accessible - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
No power supply
19 cm
49.7 cm
44.9 cm
6.14 kg
Brand: CoolerMaster
Price Range Ex VAT: 50 - 100
