Your basket is empty
CoolerMaster SickleFlow 120 Green LED Fan - 120mm, 2000RPM
Quicklinx: 8K3GWS00 Mfr#: R4-L2R-20AG-R2
Case cooling is becoming more essential these days. The better airflow inside your system, the cooler and more stable system you will get.
Cooler Master SickleFlow 120 2000 RPM Green LED - case fan
Case fan
Package Content
3-pin plug to 4-pin Molex adapter
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Long life sleeve bearing
Rotation Speed
2000 rpm
Air Flow
69.7 cfm
Noise Level
19 dBA
Power Connector
3-pin plug, 4 pin Molex connector
Rated Voltage
12 V
Green LEDs
116 g
Case fan
Package Content
116 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
2000 rpm
Air Flow
69.7 cfm
Air Pressure
2.94 mm
Noise Level
19 dBA
Power Connector
Rated Voltage
12 V
Rated Current
0.35 A
Power Consumption
4.2 W
Green LEDs
Mounting Kit
Included
RoHS
Sound Emission
19 dBA
