R4 series fans offer a unity of maximum rotational speed and optimum airflow. Using a unique long-life sleeve bearing fan, the R4 series offers long life rating of 50,000 hours. R4 series fans perform at a maximum of 69CFM at 2000RPM.
- Cooler Master R4-L2R-20AC-GP - case fan
- Product Type
- Case fan
- Package Content
- Screws, 3-pin plug to 4-pin Molex adapter
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long life sleeve bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 69 cfm
- Power Connector
- 3-pin plug, 4 pin Molex connector
- Blue LEDs
- 12 cm x 12 cm x 2.5 cm
- 116 g
- Product Type
- Case fan
- Package Content
- 12 cm
- 12 cm
- 2.5 cm
- 116 g
Heatsink & Fan
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 2000 rpm
- Air Flow
- 69 cfm
- Power Connector
- Blue LEDs
- RoHS
- Sound Emission
- 19 dBA
