Product
CoolerMaster Notepal U2 Plus Cooler upto 17'' Laptops - Black
Quicklinx: 8RD7WS00 Mfr#: R9-NBC-U2PK-GP
Cooler Master Notepal U2 Plus is a slim and study laptop cooling pad. A sandblasted aluminum surface spreads heat away from hotspots. Then two fully adjustable 80 mm fans remove the heat. The result is a cooler, faster computer.
  • Patent moveable cooling fans
    High definition sound standard is a groundbreaking technology that eliminates distortion so you'll hear sound the way it was meant to be heard.
  • Slim and lightweight - a perfectly fit
    ETL technology is a revolutionary patented technology that allows the speaker to move more freely. The result is crystal clear clarity across the entire frequency response range.
  • No more messy wires
    Booming bass flows through your skull yet is subdued enough to give the fidelity the richness it deserves.
  • Transforms into a laptop carry case
    Carry and protect your laptop in the NotePal U2 Plus with the included safety belt.
Cooler Master Notepal U2 Plus - notebook fan
Notebook fan
Fans Qty
Dual
Fan Diameter
80 mm
Fan Height
10 mm
Rotation Speed
2000 rpm
Air Flow
31 cfm
Noise Level
21 dBA
Product Material
Plastic, aluminium, rubber
34.6 cm x 6 cm x 28.2 cm
650 g
USB powered
Notebook fan
Product Material
34.6 cm
6 cm
28.2 cm
650 g
Heatsink & Fan
Fans Qty
2
Fan Diameter
80 mm
Fan Height
10 mm
Rotation Speed
2000 rpm
Air Flow
31 cfm
Noise Level
21 dBA
USB powered
