- High air flow for maximum cooling performance.
- Quiet operation with low RPM.
- RoHS compliance for protecting the environment.
- Compatible with Cosmos S, ATCS 840, HAF 932, HAF 922(1) and Storm Sniper(1).
- Adds extra cooling for graphics cards when installed on side panels.
(1) No LED On/Off function support
- Cooler Master MegaFlow 200 - case fan
- Product Type
- Case fan
- Package Content
- 3-pin plug to 4-pin Molex adapter
- Blue
- Fan Diameter
- 200 mm
- Fan Height
- 30 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 700 rpm
- Air Flow
- 110 cfm
- Power Connector
- 3-pin plug, 4 pin Molex connector
- Blue LEDs
- 266 g
- Product Type
- Case fan
- Package Content
- 266 g
- Blue
Heatsink & Fan
- Fan Diameter
- 200 mm
- Fan Height
- 30 mm
- Fan Bearing
- Sleeve bearing
- Rotation Speed
- 700 rpm
- Air Flow
- 110 cfm
- Power Connector
- Blue LEDs
- Mounting Kit
- Included
- RoHS
- Sound Emission
- 19 dBA
