Inspired by luxurious supercars, the exterior of the Cosmos II melds aluminum, steel, and mesh into an elegant artistic piece. It maintains its trademark Cosmos profile and outlook with its reinforced aluminum rails while being further refined for today's advancements in air/water cooling, peripheral support, and styling. Large swinging aluminum side panels and sliding doors lend to its stylish and smooth movements to access ports, drives, and system hardware. With the Cosmos II, build as you wish as the options are endless.
- Cooler Master Cosmos II - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Midnight black
- I/O Connectors
- 4 x USB 2.0 , 2 x USB 3.0 , 1 x eSATA , 1 x microphone , 1 x headphones
- Supported Motherboards
- ATX, microATX, Extended ATX, SSI CEB, SSI EEB, XL-ATX
- System Cabinet Features
- Meshed front panel
- Power Device
- No power supply (EPS12V/ PS/2)
- 34.4 cm x 70.4 cm x 66.4 cm
- 22 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 11
- Front Accessible Bays Qty
- 5
- Product Material
- Aluminium
- Midnight black
- Cooling System
- Front: 200 mm fan x 1 / 700 rpm / 19 dBA / 1 x 120/140 mm fan supported , Top: 120 mm fan x 1 / 1200 rpm / 17 dBA , Rear: 140 mm fan x 1 / 1200 rpm / 19 dBA , Side: 120 mm fan mount x 2 , Top: 120 mm fan mount x 3 / 1 x 200 mm fan or 2 x 140 mm fan supported , Internal: 120 mm fan mount x 1 , Internal: 120 mm fan x 2 / 1200 rpm / 17 dBA
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 2 (total) / 2 (free) x front accessible - 3.5" x 1/3H , 11 (total) / 11 (free) x internal - 3.5" x 1/3H
- Expansion Slots
- 11 x Expansion Slot
- 4 x USB 2.0 , 2 x USB 3.0 , 1 x eSATA , 1 x microphone - mini-jack , 1 x headphones - mini-jack
- Power Device
- No power supply
- Specification Compliance
- EPS12V/ PS/2
- Max Supported Qty
- 1
- 34.4 cm
- 70.4 cm
- 66.4 cm
- 22 kg
- Limited warranty - 2 years
