CoolerMaster Cooler Hyper 612 V2 Fan CPU Cooler
Quicklinx: B19VWS00 Mfr#: RR-H6V2-13PK-R1
Cooler Master Hyper 612 Ver. 2 - Processor cooler - ( LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket ) - aluminium with copper base - 120 mm
Cooler Master Hyper 612 Ver. 2 - processor cooler
Processor cooler
Compatibility
Heatsink Material
Aluminium with copper base
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
800-1300 rpm
Air Flow
26.6 - 44.2 cfm
Noise Level
11 - 20 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support, 6 copper heatpipes (6 mm), Continuous Direct Contact (CDC) technology, X-Vent technology
12.89 cm x 15.01 cm x 16.04 cm
Processor cooler
12.89 cm
15.01 cm
16.04 cm
Heatsink & Fan
Compatible With
Heatsink Material
Heatsink Dimensions
160.4 mm x 139 mm x 102 mm
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
800-1300 rpm
Air Flow
26.6 - 44.2 cfm
Air Pressure
0.6 - 1.6 mm
Noise Level
11 - 20 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.09 A
Power Consumption
1.08 W
Mounting Kit
Included
Limited warranty: - 2 years
