The very successful B-series has been revised. A complete circuit layout and components make it compliant to the regulations. The biggest difference for the B-series is that it only has a single rail +12 V DC out with a max current of 38 A. This now means that all Cooler Master power supplies makes use of a single rail instead of multi rail.
- Cooler Master B500 ver.2 - power supply - 500 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- +3.3V - 20 A , +5V - 20 A , +12V - 38 A , -12V - 0.3 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- 3-year warranty
- ATX12V 2.31
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 200 - 240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- Efficiency
- 85%+
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, short-circuit protection, single 12V rail, hydrodynamic bearing cooling fan, fan speed control
- TUV, Energy-Related Products (ErP) Lot 6, EAC, ErP 2013
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 15 cm
- 14 cm
- 8.6 cm
- Shipping Width
- 20.2 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 9.6 cm
- Shipping Weight
- 1.63 kg
