Maclocks Brand-able Floor Stand is an enclosure stand with empty space allowing you to put a custom message or branded panel making it a great display solution for stand alone environments.
- Compulocks BrandMe - VESA Floor Stand - Black - stand
- Product Type
- Stand - floor-standing
- Adjustments
- Tilt
- Recommended Use
- Tablet
- Material
- Aluminium
- Black
- Material
- Aluminium
- Black
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Floor-standing
- Cable Management
- Integrated cable management
- Adjustments
- Tilt
- Portrait to landscape movement
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CSCJ 036374 Condition: Customer return - item has been used and shows signs of use |
£35.11 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
