Compulocks Maclocks Rokku Secure Enclosure Wall Mount for iPad Air
Quicklinx: CSCHWS00 Mfr#: 260ROKB
From the premium line of products, Rokku from lock or rock in Japanese, represents a design of Tablet Enclosure with dual locks and a rock solid frame.
The Rokku design includes high security cylinder lock mechanism and a recessed frame for a full tamper proof enclosure. Access to the On/Off and volume buttons are blocked while still allowing for charging and limited audio port access.
Constructed of high grade aluminum makes the Rokku iPad enclosure extremely lightweight and durable at the same time. With soft edges and rounded corners the aesthetic of this enclosure is very appealing and fits all display environments.
Although very thin at only 3cm (1.18 in) deep, the sunken frame design allows for full cable management adding another level security to your Tablet.
The Rokku Tablet enclosure includes a standard 100mm x 100mm VESA pattern which will allow it to be mounted to flat surfaces and the full line of mounts.
Compulocks Rokku iPad / Galaxy Security Lock tablet Enclosure enclosure - Anti-Theft - for tablet - black
Enclosure (Anti-Theft) - wall-mountable
Recommended Use
Tablet
Samsung Galaxy Tab A (9.7 in), Tab S2 (9.7 in), Tab S3 (9.7 in)
AV Furniture
Enclosure
Design
Anti-Theft
Recommended Use
Tablet
Placing / Mounting
Wall-mountable
