- Sahara stand - for flat panel - gloss black
- Product Type
- Stand - desktop
- 40.5 cm x 14.4 cm x 80.5 cm
- 17 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 42"-46"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 400 mm, 300 x 300 mm, 400 x 600 mm
- Max Mounting Pattern Size
- 680 x 475 mm
- Material
- Glass, steel
- Gloss black
- Designed For
- CleverLCD Touch 42, 55
- 40.5 cm
- 14.4 cm
- 80.5 cm
- 17 kg
- Material
- Glass, steel
- Gloss black
AV Furniture
- Stand
- Recommended Use
- Flat panel
- Placing / Mounting
- Desktop
- 680 x 475 mm
- 42"-46"
- Swivel adjustment
- Designed For
- Sahara CleverLCD Touch 42, 55
