Cisco Wireless-G Business Ethernet Bridge
Customer rating: 4.0* (Write a review)
Quicklinx: 4YVMWS00 Mfr#: WET200-G5
Bring separate Ethernet networks together - even if they're in different offices or nearby buildings. Cisco Small Business WET200 Wireless-G Business Ethernet Bridge uses Power over Ethernet (PoE) for ease of installation, even without proximity to an electrical outlet. Advanced security features include support for WEP, WPA, and WPA2 encryption using EAP (Extensible Authentication Protocol), which gives small businesses the protection they need to communicate and transfer data securely. The integrated quality-of-service (QoS) features provide consistent voice and video quality on both wired and wireless networks, enabling the deployment of business-quality voice over Internet Protocol and video applications.
Cisco Small Business WET200 - bridge - Wi-Fi - desktop
Bridge - 5-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Auto-sensing per device, DHCP support, PoE, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), traffic shaping, port mirroring, firmware upgradable, MIMO technology, WMM support, ACL support, QoS, RangeBooster technology
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
20.5 cm x 17 cm x 19.5 cm
345 g
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
MAC Address Table Size
1K entries
Encryption Algorithm
128-bit WEP, 64-bit WEP, TLS, PEAP, WPA, WPA2, WPA-PSK, 256-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, ICES-003, FCC
Status Indicators
Port status, power
LAN: 5 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
1.8 dBi
External power adapter
1 x network cable
OS Provided
Linux
20.5 cm
17 cm
19.5 cm
345 g
Limited warranty - 3 years
10 - 85%
Customer reviews
Write a review for the Cisco Wireless-G Business Ethernet Bridge here!
very configurable robust device
Reviewed by arkid. Review Posted 05/10/2008
Ive just got my wet200. If your wanting to extend your home/office network to another part of your building/s but dont have the cable inbetween then this could be a solution.
i needed to share multiple lan devices off a wifi signal from my neighbour. this box allowed that, as it can share its connected wifi link with 5 lan ports via its switch capacity.
there was a slight issue as i have to connect to a wifi network with wep, not the better newer wap security standard.
i had been given the encoded passkey value but was inserting that into the wet200's interface in the wrong box. their interface provides a space for password conversion into numeric passkeys. i had been pasting my passkey into the password conversion box, resulting in a wrong passkey being assigned. anyway, my fault really.
as soon as i realised this i got it up and running. great big antennae really help to grab the wifi signal and it seems stronger than my laptop connected directly from tests.
  • Overall 4*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
