Cisco Unified IP Phone 7975G VoIP SCCP, SIP - 8-line operation - Silver/Dark Grey
Quicklinx: C6FHWS00 Mfr#: CP-7975G=#Disney
The Cisco Unified IP Phone 7975G demonstrates the latest advances in VoIP telephony, including wideband audio support, backlit color touchscreen display, and an integrated Gigabit Ethernet port. It addresses the needs of the executive or major decision maker, administrative assistants, and those working with bandwidth-intensive applications on co-located PCs. This IP phone includes a large, backlit, easy-to-read color display for easy access to communication information, timesaving applications, and features such as date and time, calling party name, calling party number, digits dialed, and presence information. It also accommodates Extensible Markup Language (XML) applications that take advantage of the display. The phone provides direct access to eight telephone lines (or combination of lines, speed dials, and direct access to telephony features), five interactive soft keys that guide you through call features and functions, and an intuitive four-way (plus Select key) navigation cluster. A hands-free speakerphone and handset designed for high-fidelity wideband audio are standard, as is a built-in headset connection.
Cisco Unified IP Phone 7975G - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SCCP, SIP
Voice Codecs
G.722, G.729a, G.729ab, G.711u, G.711a, iLBC
Multiline Operation Capability
8-line operation
Speakerphone
Yes (digital duplex)
Voice Mail Capability
Call Services
Voice Mail
Display
LCD display - colour - Yes
Display Features
Wallpaper
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Body Colour
Silver, dark grey
VoIP phone
Body Colour
Silver, dark grey
Body Material
ABS plastic
Phone Features
Call Services
Voice Mail
Dialer Type
Keypad
Dialer Location
Base
8-line operation
Conference Call Capability
Speakerphone
Menu Operation
Function Buttons
Speakerphone button, headset button, menu navigation keys, mute button
Programmable Buttons Qty
8
Volume Control
Ringer Control
Ring Tones
24
Firmware Upgradable
Additional Functions
Web browser
IP Telephony
Main Features
VoIP
VoIP Protocols
SCCP, SIP
Voice Codecs
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
128 bit AES
Power Over Ethernet (PoE) Support
Network Protocols
TFTP
Network Ports Qty
Voice Features
Echo cancellation (ECN)
Network Features
Class 3 PoE
Display
Display Location
Base
Diagonal Size
5.6"
Display Resolution
320 x 240 pixels
Colour Depth
16-bit (65000 colours)
Display Information
Date, time
Backlit
Wallpaper
Headset jack
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Dimensions & Weight (Base)
26.7 cm
15.2 cm
20.3 cm
1.6 kg
