Cisco TelePresence System SX20 Quick Set
Quicklinx: DCL1WS00 Mfr#: CTS-SX20N-12X-K9
The Cisco TelePresence SX20 Quick Set (SX20 Quick Set) can transform any flat panel display into a sleek and powerful telepresence system. The SX20 Quick Set is designed to deliver high definition video and multiparty conferencing with the flexibility to accommodate various room size and configurations - all at a value price. The SX20 Quick Set supports embedded capability for multipoint support with Cisco TelePresence MultiSite technology, enabling users to add three additional participants to a telepresence call.
SX20 Quick Set combines a powerful codec, three camera choices, and a dual-display option in an easy-to-deploy and easy-to-use solution. Whether you're a small business just getting started with telepresence or a large enterprise looking to expand your existing deployment, the SX20 Quick Set delivers the performance you would expect from more expensive systems - in a compact and feature-rich package. Cisco TelePresence SX20 Quick Set is designed to truly extend the power of in-person to everyone, everywhere.
  • Seamless connectivity
    With dual HDMI and DVI inputs, alongside Ethernet 10Base-T/100Base-TX/1000Base-T support, the Cisco TelePresence System SX20 ensures a wide range of connectivity options for various devices and networks, facilitating effortless integration into existing setups.
  • High-definition video
    Equipped with a Precision HD 1080p 12x Camera and supporting resolutions up to 1920 x 1080, this video conferencing kit delivers crisp, clear, and vibrant video quality, making remote communications more effective and engaging.
  • Versatile audio inputs
    Featuring multiple audio inputs, including external microphones and a wireless remote control, the system offers flexible audio solutions to meet the demands of dynamic conferencing environments.
  • Robust environmental adaptability
    Designed to operate within a broad range of temperatures from 0°C to 35°C, the Cisco TelePresence System SX20 Quick Set is built to perform reliably in diverse environmental conditions, ensuring uninterrupted operation.
  • Comprehensive standards compliance
    Adhering to stringent standards such as CSA C22.2 No. 60950-1-07, EN 60950-1, and FCC Part 15 B, this system meets high safety, reliability, and quality benchmarks, providing peace of mind in its deployment and use.
Cisco TelePresence System SX20 Quick Set with Precision HD 1080p 12x Camera - video conferencing kit
Video conferencing kit
Digital Signaling Protocol
H.323, SIP
Data Compression Protocol
G.711, G.722, H.263, H.264, H.263+, G.722.1
Video Input
Digital video camera - HD-SDI output, HDMI output
Video Output
Codec board
Audio Input
Microphone
Input Device
Remote control (wireless)
Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet
90 days warranty
Dimensions & Weight Details
Main system - Width 30 cm Depth 18 cm Height 3.4 cm Weight 1.4 kg
Modem
H.323, SIP
Video Input
Digital video camera (colour) - external
Interface Type
Digital Video Capture Resolution
1280 x 720, 1920 x 1080
Video Output
Codec board - external
Supported Display Graphics
VGA (640x480), XGA (1024x768), SVGA (800x600), HDTV (1920x1080), HD (1280 x 720), 1280x768, 1024x576, 704x576
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Audio Input
Microphone - external
Input Device
Remote control
Wireless
Network adapter
Wired
Network / Transport Protocol
TCP/IP, NTP, DHCP, DNS
2 x display / video - HDMI output - 19 pin HDMI Type A , 2 x microphone - input - mini-phone 3.5 mm 4-pole , 1 x audio - input - mini-phone 3.5 mm , 1 x display / video - input - DVI , 1 x display / video - input - 19 pin HDMI Type A , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x USB
EN55022 Class B, FCC Part 15 B, EN 60950-1, CSA C22.2 No. 60950-1-07
Power supply
40 Watt
Software Included
Cisco Collaboration Endpoint 8
Limited warranty - 90 days
35 °C
10 - 90% (non-condensing)
