Cisco Spark Board 55 - 55" 4K Edge LED LCD Multi-touch Wireless
Quicklinx: CV0KWS00 Mfr#: SPARK-BOARD55-K9
The Cisco Spark Board is an all-in-one device that provides everything you need to collaborate with your teams in physical meeting rooms: You can wirelessly present, white board, and have video and audio calls. And it securely connects to your virtual teams through the Cisco Spark service via your Cisco Spark app-enabled devices, so you can take your meetings and content on the road.
The Cisco Spark Board helps teams collaborate in physical meeting rooms, but also securely connects to virtual meeting spaces to facilitate continuous workflow before, during, and after everyone has left the physical conference room. The Cisco Spark Board draws its power from the Cisco Spark service, which combines meeting, messaging, calling, and new white boarding capabilities on any Cisco Spark app-enabled device. Registration to the Cisco Collaboration Cloud lets you store everything created on the Cisco Spark Board directly in the cloud and associate it to a virtual Cisco Spark space, so you can take your work wherever you go. The Cisco Spark Board solution offers an integrated, secure and comprehensive life-cycle approach to teamwork that is as yet unimagined, and thus unmatched, by any other solution on the market.
The Cisco Spark Board is a fully self-contained system on a high-resolution 4K 55-inch LED screen. With an integrated 4K camera, embedded microphones, and a capacitive touch interface, the Cisco Spark Board brings intelligence, style, and usability to meeting rooms, from small to large. Designed with minimal wires, so as to not disrupt its elegance, Cisco's latest collaboration device is touch-based for easy and rich team collaboration. Not only is the Cisco Spark Board beautiful to behold and effortless to use, it is also affordable to acquire and easy to install and deploy, so that it can be a fixture in all of your conference rooms.
  • Wireless presentation
    No wires required to share presentation, locally or remotely, from a laptop (HDMI available).
  • Digital whiteboard
    Easily white board with the Cisco Spark Pen or your finger on the Cisco Spark Board and automatically save content to a Cisco Spark space. Connects to white boarding capability on any Cisco Spark app-enabled device.
  • Audio/video conferencing
    High-quality video conferencing (Cisco Spark and Session Initiation Protocol [SIP]). High-fidelity audio conferencing.
  • Industrial design
    Built-in microphones and wireless sharing add to the clean, no-wire aesthetics. Fixed-lens camera uses an 86-degree wide field of view to capture virtually the entire room. High-resolution 4K screen shows detailed content beautifully.
  • Usability
    Easy-to-understand activity circles correspond to the basic activities and workflows that users need to get their work done. Intuitive navigation, such as a home button and touchscreen, is a staple of mobile devices and familiar to users. Consistent user interface and workflow across the Cisco Spark Board and Cisco Spark app minimize the user's learning curve. Familiar capacitive touch capability is the same as on smartphones and tablets, and allows for two-point multi-touch, which lets two people work on the board at the same time.
  • Continuous workflow
    Cloud registration lets everything created on the Cisco Spark Board be stored directly and securely in the cloud and associated to a virtual Cisco Spark space. Team members can pick up wherever they left off on the Cisco Spark Board when they leave the physical room; work can continue from a different location, time, or device, such as another Cisco Spark Board or any other Cisco Spark app-enabled devices (smartphones, tablets, laptops). Cisco Spark Board and Cisco Spark service solution together provide end-to-end encryption, so your communications and content are secure.
  • Intelligent views
    Powerful 4K camera captures high-resolution image of virtually the entire room. Intelligent software algorithms enable future capabilities such as automatic framing for the best possible views and active speaker tracking (future software release).
  • Intelligent audio
    Built-in 12-microphone array amplifies sound quality - as if a microphone has been extended to each speaker. Automatically modulates the active speaker so that clear audio is delivered to the far end, whether the speaker is close to or from away from the Cisco Spark Board. No microphone wires to detract from the aesthetics of the Cisco Spark Board. Powerful microphones cover a room with 8 to 10 people.
  • Intelligent proximity
    Cisco Spark Board automatically wakes up when it detects a Cisco Spark app-enabled user entering the room and suggests an activity to choose from. Wireless sharing of documents from a laptop is enabled both in and out of a conference call; connect seamlessly to personal and mobile devices using ultrasound (no need for dongles, adapters, typing in PINpin codes, etc.). Basic endpoint control of the Cisco Spark Board can be done through your Cisco Spark app-enabled mobile device (make and disconnect calls, etc.).
Cisco Webex Board 55 - video conferencing device - 55 in
Video conferencing device
1.283 m x 4.9 cm x 81.4 cm
39.8 kg
Display
55"
Video Input
Digital camera
Audio Input
12 microphones
Audio Output
Speaker(s)
Network adapter - Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
90 days warranty
1.283 m
4.9 cm
81.4 cm
39.8 kg
Built-in Devices
Microphone, stereo speakers, camera, capacitive touch screen
Display
Diagonal Size
55"
Image Contrast Ratio
4000:1
Response Time
5.5 ms
Monitor Features
LED Technology
Video Input
Digital camera (colour) - integrated
Audio Input
12 microphones - integrated
Audio Output
Speaker(s)
Network adapter
Wireless, wired
Network / Transport Protocol
NTP, DHCP
Automatic gain control (AGC), acoustic echo cancellation
1 x audio / video - HDMI , 1 x audio - line-out - mini-phone 3.5 mm , 2 x PoweredUSB 3.0 , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
FCC, RoHS, WEEE, NRTL, Directive 2002/96/EC, Directive 2011/65/EU, EDID compatible, FCC CFR47 Part 15 B Class A, Directive 2014/35/EU, Directive 2014/30/EU, Directive 2014/53/E
Power supply - internal
237 Watt
Limited warranty - 90 days , Limited warranty - advance parts replacement - 10 days
35 °C
10 - 90%
