Cisco Small Business WAP371 Radio Access Point 802.11a/b
Quicklinx: B24DWS00 Mfr#: WAP371-E-K9
Type: Radio access point
Connectivity: Wireless
Speed: 950Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
£113.69 ex VAT
£136.42 inc VAT
Deliver high-speed wireless connectivity and guest access more securely and reliably in your small business. The Cisco WAP371 wireless-AC/N dual radio access point with single point setup is a simple yet powerful, high-performance access point. It offers business-class features such as Gigabit Ethernet connectivity, a captive portal for customized guest access, and robust security.
Cisco Small Business WAP371 - radio access point
Radio access point
External
Europe
RAM
64 MB
Flash Memory
32 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
23 cm x 23 cm x 4.3 cm
740 g
Radio access point
23 cm
23 cm
4.3 cm
740 g
Europe
Processor / Memory / Storage
RAM
64 MB
Flash Memory
32 MB
External
Wireless
Data Transfer Rate
950 Mbps
Spread Spectrum Method
OFDM
Network / Transport Protocol
DHCP, Bonjour
Remote Management Protocol
SNMP 3, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN, wireless
Auto-sensing per device, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, DFS support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Multiple SSID support, wireless bridge mode, reset button, IPv4 support, 3T3R MIMO technology, rogue access point detection, DHCP client, ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Gain Level
2 dBi
1 x 1000Base-T (PoE+) - RJ-45
1 x network cable
ICES-003, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, AS/NZS 4268, FCC Part 15.407, EN 300 328, EN 301 893, CAN/CSA-C22.2 No. 60950-1
PoE+
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
B24D C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.44
Speed: 950Mbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Cisco
Price Range Ex VAT: 100 - 150
