Cisco Small Business SG350X-48P - Switch - Managed - 48 x 10/100/1
Quicklinx: DQN2WS00 Mfr#: SG350X-48P-K9-UK
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
17 in stock
£894.28 ex VAT
£1,073.13 inc VAT
The Cisco 350X Series Stackable Managed Switches are a new line of stackable managed Ethernet switches that provide the rich capabilities you need to support a more demanding network environment at a very affordable price. The Cisco 350XG models provide 10 Gigabit Ethernet, providing a solid foundation for your current business applications as well as those you are planning for the future. In addition, these switches are easy to deploy and manage without a large IT staff. The SG350X platforms are Cisco's most cost-effective platforms with 10 Gigabit Ethernet and stacking.
  • ETHERNET PORT CONFIGURATION
    48-port 10/100/1000, 4 x 10G uplinks (SFP+)
  • POWER OVER ETHERNET
    48 PoE ports with 382W total power budget, PoE, PoE+, 60W PoE
  • CONFIGURATION & CONTROL
    Stackable (4 units), on-box WebUI, CLI, SNMP, Cisco FindIT Network Manager, PnP, Auto Smartports, auto-discovery, zero-touch deployment
  • L2+/L3 FEATURES
    Static routing, QoS, Voice/Guest VLAN, MSTP, IGMP Snooping, Time-based Access Control Lists, 802.1x, Web-based Authentication, IPv6 First Hop Security, IP Source Guard
  • PEACE OF MIND
    Limited-lifetime warranty, next-business-day replacement, one-year technical support, and free software fixes for the term of the warranty
Cisco Small Business SG350X-48P - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x combo 10 Gigabit SFP+ + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
382 W
Performance
Switching capacity (64-byte packet size): 130.94 Mpps , Switching capacity: 176 Gbps
MSTP instances: 16 , Active VLANs: 4096 , IPv4 routes (static): up to 8000 , IPv6 routes (static): up to 6000 , ACL entries: up to 2000
MAC Address Table Size
64K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), MLDv2, MLD, CIDR
Remote Management Protocol
SNMP 2, SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI, SCP
Flow control, Layer 3 switching, DHCP support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), IP Precedence, DHCP server, MLD snooping, Dynamic ARP Inspection (DAI), reset button, Cable Diagnostics Function, Uni-Directional Link Detection (UDLD), IPv4 support, DHCP relay, Port Security, Remote Switch Port Analyzer (RSPAN), DHCP client, Energy Efficient Ethernet, Management Information Base (MIB), Class of Service (CoS), Generic Attribute Registration Protocol (GARP), Generic VLAN Registration Protocol (GVRP), Duplicated Address Detection, Type of Service (ToS), DiffServ Code Point (DSCP) support, 4 fans, Time-controlled ACLs support, 3MB packet buffer, Storm Control, IP source guard, ARP inspection, Bridge protocol data unit (BPDU), Internet Control Message Protocol (ICMP), Secure Copy (SCP), Cisco Discovery Protocol, IGMP querier, VLAN Double Tagging (Q-in-Q), VLAN mirroring, DNS client, Voice VLAN, VLAN management, Secure Core Technology (SCT), Private VLAN Edge (PVE), LLDP-MED, Head-of-line (HOL) blocking, IP/Mac/Port Binding (IPMB), Secure Sensitive Data (SSD), Private VLAN, ISATAP tunnel support, RA guard
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3at, IEEE 802.3az
AC 120/230 V (47 - 63 Hz)
44 cm x 45 cm x 4.4 cm
5.82 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
382 W
Performance
64K entries
Jumbo Frame Support
9000 bytes
Max Units In A Stack
4
Routing Protocol
Encryption Algorithm
MD5, SSL
Authentication Method
RADIUS, TACACS, TACACS+
X ARM: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
System, link/speed, master, stack
32 x 1000Base-T RJ-45 30 W , 16 x 1000Base-T RJ-45 60 W , 2 x 10Gbit LAN RJ-45/SFP+ uplink , 2 x 10GBase-X SFP+ uplink , 1 x console RJ-45 , 1 x management (Gigabit LAN) , 1 x USB Type A
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
164,614 hours
UL 60950, FCC Part 15 A, CSA 22.2, USGv6
United Kingdom
44 cm
45 cm
4.4 cm
5.82 kg
Limited warranty - replacement - lifetime - response time: next business day
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 48
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: 750 - 1000
