Cisco 110 series unmanaged switches deliver basic network connectivity and reliability for small businesses that's easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Cisco. Just plug it in, connect your computers and other business equipment, and get to work.
Cisco 110 series unmanaged switches, part of the Cisco Small Business networking solutions, are a line of unmanaged switches that provide wire-speed fast Ethernet and Gigabit Ethernet connectivity to connect your small business office. These switches are designed to suit any office space with basic network needs and to optimize power efficiency. They use less power and provide the robust, reliable connectivity your business demands, as well as support for advanced features. A business-class, affordable network solution, Cisco 110 series switches bring the proven reliability and investment protection of Cisco networking solutions to your small business.
ETHERNET PORT CONFIGURATION
8-port 10/100/1000 Gigabit -
POWER OVER ETHERNET
4 PoE ports with 32W total power budget -
PLUG AND PLAY
Simple set up with no software to install or configuration needed -
PEACE OF MIND
Limited-lifetime warranty and one-year technical support -
SUPPORTED AUTOMATIC FEATURES
Quality of service (QoS), loop detection, and cable diagnostics
- Cisco Small Business SG110D-08HP - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 + 4 x 10/100/1000 (PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 32 W
- Performance
- Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 11.9 Mpps
- Capacity
- QoS hardware queues: 4
- Jumbo Frame Support
- 9216 bytes
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), Weighted Round Robin (WRR) queuing, store and forward, Quality of Service (QoS), Cable Diagnostics Function, fanless, Energy Efficient Ethernet, loop prevention, security lock slot (cable lock sold separately)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
- 16 cm x 12.85 cm x 3 cm
- 550 g
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 32 W
- Performance
- Capacity
- 9216 bytes
- RAM
- 128 MB
- Flash Memory
- 128 MB
- Status Indicators
- System, link/activity
- 4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE
- Power Device
- External power adapter
- UL 60950, FCC CFR47 Part 15, FCC Part 15 A, CSA 22.2
- Localisation
- United Kingdom
- 16 cm
- 12.85 cm
- 3 cm
- 550 g
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
Cisco Gigabit Ethernet SX Mini-GBIC | In Stock | £105.43 |
Cisco Gigabit Ethernet LX Mini-GBIC SFP Transceiver | In Stock | £133.99 |
